04 2500hd one piece driveshaft
Old Sep 1, 2018 | 09:20 AM
rpm-inc's Avatar
Default 04 2500hd one piece driveshaft
I was looking into getting a 5" aluminum shaft made for my regular cab long bed 04 2500hd 2wd turbo gas truck. Found a local shop that says he has built many for silverados both 2wd and 4wd. I only have 1.25" clearance right now from the stock 3.5 driveshaft to the torsion bar cross member. I know the carrier bearing support would have to be cut off. I don't think I could even get a straight driveshaft in with that crossmember, not to mention the minimum 2" clearance to anything the shop recommends.
What am I missing? Cut up the crossmember and weld in a big u?
Old Sep 16, 2018 | 08:47 PM
stealthperf's Avatar
I did the same thing... Custom 1 piece aluminum on my crew cab 2500 4x4 lowered... Ran out of room where the carrier bearing was.. I cut it and welded flat stock in.
Old Sep 16, 2018 | 09:06 PM
rpm-inc's Avatar
Cool thanks. I did replace all the ujoints and the center bearing. so far so good.
LQ4 Tank
Oct 22, 2014 10:27 PM
tiffo60
64
Feb 13, 2013 08:01 AM
.James.
Dec 31, 2010 07:56 AM
93ChevExt5.7
Nov 8, 2006 07:10 PM
