03 Chevy Silverado 4.8 t-56 swapped
Old Nov 22, 2016 | 01:53 PM
Dayton225's Avatar
Registered User
Default 03 Chevy Silverado 4.8 t-56 swapped
I recently bought a 03 rcsb Silverado with the 4.8 and the last owner swapped it to a t56 trans, and I guess he never got around to fixing the speedo on the truck, I thought it was the cluster messed up but it wasn't. Anyone have any ideas to fix it?
Old Nov 22, 2016 | 02:14 PM
mvrk10256's Avatar
Not sure the VSS is the same. Check to see if its plugged in at all. I think if it is you should get a speed - not the right speed. There may be a conversion box or simply a parameter in HPT to change.
Old Nov 22, 2016 | 09:12 PM
TrendSetter's Avatar
vss is the same signal, teeth per mile maybe different though.
Old Nov 23, 2016 | 08:35 AM
firebladeJJ's Avatar
any tuner worth a damn can fix it. I did the same swap couple months ago in my truck, changed the VSS to the correct tooth count; like TrendSetter said.
