01 ecsb 2wd 4l60 to 4l80
Im sure theres already a thread out there for this but im not sure where. I have a 01 silverado ecsb with a 2 peice drive shaft that i want to swap trans on. And I want to know what yoke and u joint i need, what plug i need and if i need a specal tourque convertor?
You'll need the transmission, new cross member mount or mod the factory one, mod the wire harness to make it work, new drive shaft or shorten a section of yours because the 4L80e is longer, different flex plate and converter.
Then a custom tune to make everything work. I suggest more reading on your part to get the exact parts you will want.
