00 camaro trans fit 01 silverado
Old Sep 30, 2012 | 01:14 PM
speedchain's Avatar
Registered User
Question 00 camaro trans fit 01 silverado
I've searched an can not find the answer I'm lookin for. My question is will a 2000 camaro z28 ls1 4l60e trans fit in my 2001 silverado 1500 2wd. Does the tailend mount different? Can I just swap the tailend with the one that's on the truck now? If the car one is different?
Any info greatly appreciated.
Old Sep 30, 2012 | 08:51 PM
fastnblu's Avatar
I can't be 100% certain, but maybe someone can give u a more definite answer than what I'm gonna say.
I do know if it was an LT1 tranny it differs from LS style, but after that, I can't be sure if it's a different length tailshaft housing.
What I'd do to rule out that uncertainty is, measure from flange where it meets main tranny housing to where it ends (by tailshaft seal) on your truck. Get Camaro dimensions, then go from there.
Old Oct 3, 2012 | 03:29 AM
1FastBrick's Avatar
Custm2500's Rude Friend
The transmission from an LS1 equipped car is basically the same. You should only need to change the tail shaft housing. I Believe the tail housing is just cosmetically different and could be used in a pinch.
Verify the Bell housing has the same part number cast into on both transmissions. I believe there may have been a few variations depending on application. The LS1 and LS based ruck application should be the same.
When you put the converter in make sure it is seated all the way first before bolting it up and then check your gap to the fly wheel once it is installed. there is a sticky at the top about how the Torque converter should be engaged and what type of gap you should have when done properly. If you can not pull the converter back at all don't tighten the bolts from the trans case to the engine as you can damage the pump.
Old Oct 3, 2012 | 07:54 AM
2doorfury's Avatar
Planetary gears are different, car 60e's have a 3 gear planetary and trucks have 4 gear planetary.
Old Oct 3, 2012 | 09:46 PM
1FastBrick's Avatar
Stop posting false information!!!
Old Oct 3, 2012 | 09:52 PM
TXSZ66AVLANCHE's Avatar
My backup trans is from a camaro, how do I add the extra planetary gear?
Old Oct 3, 2012 | 10:03 PM
2doorfury's Avatar
Sorry if im wrong, but thats what i was told by a very reputable trans builder. Ill make a phone call tomarrow to double check.
Old Oct 3, 2012 | 10:40 PM
1FastBrick's Avatar
Yes, Either you misunderstood or he gave you the wrong Info.
The M30 code 4L60E is the same between the LS based truck and the LS1 Camaro. The fact that the years are so close are even better. there were minor changes internally but nothing major. The planetaries are 4 pinion in the cars and trucks with the M30 code 4L60E.
The M32 found in the SS, VHO, V-MAX, Escalade, Denali's had 5 pinion planetaries front and rear. This is referred to as the 4L65E which also had a few minor internal changes.
There was no 3 pinion planetary in the front or rear of either version of this transmission.
Old Oct 3, 2012 | 10:49 PM
I forgot to use sarcasm font
Old Oct 3, 2012 | 11:21 PM
2doorfury's Avatar
what about v6 models? maybe he was refering to another type of 60e?
