General Truck Racing and Discussion Baja, Stadium, Craftsman Truck Series, Offroad, Sleds, Mudding, Monster Trucks
Drag radials on stock 17 rims
Old Aug 18, 2015 | 02:12 PM
gbbmk's Avatar
Default Drag radials on stock 17 rims
I am running a 4x4 and need to get a set of radials for the rear. My current tire size is 265/65-17 which I believe is a 30" tire. I am lookong for the tallest tire i can get with I believe is 275/50-17 m&h. I have searched to see what people are running.
Also i have 3:73 gears. I do not plan on installing on the front. Has anyone else done this? I am not looking to drop a ton on tires. It is for one week. I will buy different tires for all 4 next year.
Will a 28 inch rear tire and a 30 inch front cause issues?
Old Aug 18, 2015 | 03:12 PM
walledition's Avatar
do u plan on using it in 4x4? in that case u need the same tire size all around for sure
Old Aug 18, 2015 | 03:18 PM
Atomic's Avatar
I have a gauge for that
I ran those M&H tires are all 4, they are a 28" tire. You can use different sizes front and rear as long as you don't use 4wd. If you do use 4wd with that different of a size you will probably break the transfer case.
Old Aug 18, 2015 | 03:23 PM
gbbmk's Avatar
I wasn't planning on running 4wd because of the size difference. Unless i find a used set in decent shape
Old Aug 18, 2015 | 06:14 PM
gbbmk's Avatar
What if i went with a 16 inch rim on the rears? I dont think a 15 inch would fit over the rear brakes
Old Aug 18, 2015 | 06:47 PM
06 4.8's Avatar
Depends if you have rear drum or disc?
Old Aug 18, 2015 | 07:37 PM
gbbmk's Avatar
I found a set of 4 mickey 17 inch drags but they are 26 inch. Do you think that is to small. It puts me at 6000 rpms at 116mph in third. I dont expect to do that in the 1/4.
Old Sep 10, 2015 | 09:55 PM
silver-mod-o's Avatar
Hunt&Fisherator
Sounds pretty ideal to me. Especially if you plan on running 4wd
Old Sep 29, 2015 | 10:19 AM
madmann26's Avatar
You'll need a retune to fix the shifting and speedo read outs.
BoostedBowTie
Jan 3, 2020 06:46 PM
chopperloco
Jul 10, 2016 10:45 PM
GMCtrk
Jul 17, 2015 06:39 PM
gcsd3742
Jul 6, 2015 05:22 PM
