will this work?
Old Dec 13, 2017 | 03:08 PM
TXsilverado's Avatar
Default will this work?
my car currently has an A1000 fuel pump. I hear these things push a ton of fuel, but also generate a lot of heat. I know it's noisy as hell!
I was thinking about running 10 AN from the sump to a 10AN Y and keeping my A1000 to be turned on through a hobbs switch, and a bosch to run the engine anytime I'm not in boost. the 10AN pumps would Y into 8AN and run to the fuel rail with an 8AN from my regulator back to the tank.
I never see anyone running different pumps together. will this work, or is it a recipe for disaster?
Old Dec 13, 2017 | 05:11 PM
turboal1's Avatar
Default 2 Pumps
I did something like this on my Buick GN, 2 pumps
a driver and a boost with a Hobbs switch. a 255
in the tank and a Bosch on the frame
Old Dec 14, 2017 | 11:30 AM
will I need to put check ***** anywhere in a setup like this?
Old Dec 14, 2017 | 01:15 PM
turboal1's Avatar
Default Pumps
yes you will need check valves, on the feed side of the pumps
I think that is what i did, so i won't back feed the pumps.
I did this setup back in 1987 so it's hard to remember how
i did. it.
Snake Eater
Jul 1, 2019 06:16 AM
iLLuZioN
Jul 2, 2005 08:40 PM
Hit Man X
May 22, 2004 01:59 AM
Dogmeat
Dec 5, 2001 08:34 PM
