Walbro 450 swap, now 4 CELs - need help!
Old Apr 16, 2014 | 01:45 PM
TX Tahoe Z71's Avatar
Default Walbro 450 swap, now 4 CELs - need help!
Flex fuel pump finally died on me, so I swapped in a Walbro 450 in the stock bucket. After a multiple stage, lengthy swap (thanks in large part to Racetronix lack of quality control), I fired it up last night and CEL came on
Pulled the following codes at O'Reillys for my 2003 Tahoe 5.3 flex fuel running on E85 right now:
P0169 - incorrect fuel composition
P0452 - fuel tank pressure sensor
P0446 - Evap, vent system performance
P0463 - fuel level sensor, gauge reads empty (I think I messed this up squeezing the assembly back into the tank)
I didn't touch the fuel composition sensor nor remove or mess with the fuel tank pressure sensor. No idea about the vent system performance.
Has anyone run into these problems after a fuel pump swap? Any ideas for what needs to be fixed? I plan to replace the fuel level sender, but can I tune the rest out or are they caused by problems I need to address?
Old Apr 16, 2014 | 02:25 PM
ullose272's Avatar
smash some wires?
Old Apr 16, 2014 | 02:31 PM
Ferocity02's Avatar
Originally Posted by ullose272
smash some wires?
That would be my guess as well.
Old Apr 16, 2014 | 03:32 PM
Now that I think about it, I unbolted and moved the evap canister a bit to make room to work under there. Didn't disconnect anything intentionally, but may have jostled something loose
Old Apr 16, 2014 | 09:21 PM
Tootall's Avatar
mess up any of the quick disconnects?
gas filler tube all the way on correctly? . . . and the over fill tube?
try clearing the codes first?
Old Apr 16, 2014 | 10:11 PM
AUTOT3K's Avatar
that's what I'd do, clear them and recheck!
Old Apr 16, 2014 | 10:53 PM
Good idea, I'll do that tomorrow. I did test the pump with the module out of the tank, which may have caused some of them... hopefully
Old Apr 16, 2014 | 10:55 PM
Don't think so, and the filler and vent tubes and on and snugged down, but I'll give them a twist just to be sure they're on there.
Nope, that's probably where I should have started to see what pops back up.
Old Apr 16, 2014 | 11:03 PM
AUTOT3K's Avatar
tested the pump by cycling the key on?
Old Apr 17, 2014 | 08:19 AM
Yeah, hooked up the harnesses and fuel lines, then checked for pressure at the rail by priming the pump. Wanted to make sure everything worked before I put it all back together.
