Walbro 450 swap, now 4 CELs - need help!
Flex fuel pump finally died on me, so I swapped in a Walbro 450 in the stock bucket. After a multiple stage, lengthy swap (thanks in large part to Racetronix lack of quality control), I fired it up last night and CEL came on
Pulled the following codes at O'Reillys for my 2003 Tahoe 5.3 flex fuel running on E85 right now:
P0169 - incorrect fuel composition
P0452 - fuel tank pressure sensor
P0446 - Evap, vent system performance
P0463 - fuel level sensor, gauge reads empty (I think I messed this up squeezing the assembly back into the tank)
I didn't touch the fuel composition sensor nor remove or mess with the fuel tank pressure sensor. No idea about the vent system performance.
Has anyone run into these problems after a fuel pump swap? Any ideas for what needs to be fixed? I plan to replace the fuel level sender, but can I tune the rest out or are they caused by problems I need to address?
Nope, that's probably where I should have started to see what pops back up.
