walbro 450 questions
Old Jan 25, 2015 | 07:54 PM
GMCtrk's Avatar
Return style
Old Jan 25, 2015 | 08:08 PM
03sierraslt's Avatar
Return. I ran twin 255's on a Returnless setup with allot of meth and still waived the white flag. Building return system now. Your 450 will do allot more with a return setup and a boost references FPR.
Old Jan 25, 2015 | 08:20 PM
LPCWS6's Avatar
Would not having a return style fuel system cause my first fuel pump to fry it's wires?
Old Jan 25, 2015 | 08:38 PM
No. What wires fried? Are you running on stock wiring? I am running a stand alone harness.
Old Jan 25, 2015 | 08:53 PM
LPCWS6's Avatar
Stock wiring. Was told the wires in the gas tank that go to the pump were fried.
Old Jan 25, 2015 | 08:56 PM
Well I know a 450 pulls more amps, but the 04 up tank connector is also the upgraded one. Not sure what gauge the factory intank wiring is. I have a couple buckets in my garage, I'll have to look.
Old Jan 25, 2015 | 10:11 PM
GMCtrk's Avatar
never run stock wires with a 450. They can pull a ton of amps, well over 20 at full tilt.
Old Jan 25, 2015 | 10:27 PM
Walbro says 17 amp at 13.5v and 70psi.
Old Jan 25, 2015 | 10:37 PM
12-14 gauge would work good assuming 10" length. Technically 16 would work but I would error on the side of caution. Factory 04' up tank connector (280 series I think) is rated at 30amp.
Old Jan 29, 2015 | 11:53 PM
gansoh_hdss's Avatar
also from AZ mesa to be exact but dam now im worried, I just a got a 450 walbro yesterday, my tuner did warn me about the Chinese/knock off ones being sold on ebay. not close to your set up but still worried!!! what ebay user did you buy it from at first???
