Walbro 400LPH with stock lines?
Old Mar 26, 2013 | 10:43 PM
Atomic's Avatar
I have a gauge for that
It will be fine.....even if it did overpower the regulator, you can fix it by tuning the IFR table
Old Apr 4, 2013 | 11:10 AM
Ferocity02's Avatar
Originally Posted by slowswb
You will be fine as long you have a return on it only over flows regulator on f bodys not on a trucks do to that fact they are large! Are going to gas or e85? If you go e85 use the 450.
Found this thread on tech where guys say they are running twin 255's and twin 340's on the stock fuel system!
https://ls1tech.com/forums/forced-in...-straight.html
Old Apr 4, 2013 | 12:59 PM
219boone78's Avatar
i just ordered one off ebay for 117 to drop in the 400 where my 255 was. now, what should i do with my wiring? i herd of some type of hotwire kit??? if thats what i need, or what u did, where did u get it from.
Old Apr 4, 2013 | 01:11 PM
nonnieselman's Avatar
I am running twin 255's in the tank and both are on at the same time.. i havent gotten around to redoing it to a hobb switch. but at idle its only about 3psi more than what a single 255 was doin .
Old Apr 4, 2013 | 01:22 PM
Ferocity02's Avatar
Good info. What's your idle pressure? Mine is 56psi (with vacuum line disconnected) with a single 255, stock wiring.
Old Apr 4, 2013 | 01:42 PM
Ill have to check.. i wanna say 60psi.
Old Jul 13, 2013 | 05:03 AM
qwick02z's Avatar
Registered User
I have a new AEM 320 LPH pump in mine it works like a champ!
kr1s
Aug 24, 2015 05:34 PM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
76k10chase
Jul 17, 2015 01:48 PM
Deceptarado
Jul 8, 2015 05:24 PM
