Walbro 255 problem, need help
Old 12-14-2013, 07:55 PM
jiar577's Avatar
Default Walbro 255 problem, need help
Tried to start the truck the other day and it cranked but didn't start so I knew it was a fuel issue. An old guy saw I was having problems so he came by and told me "it's the pump, hit the gas tank and it should start".
I was thinking the guy must be crazy but kicked the tank as hard as I could anyway. Truck started right away.
It did it again today, same procedure. Both times it was almost out of fuel.
Is the pump on its way out or is it caused because of the low fuel level?
Old 12-14-2013, 07:57 PM
jiar577's Avatar
Forgot to mention, installed the pump & SC over a year ago but have put a little less than 2000 miles since then.
Old 12-14-2013, 08:47 PM
Get a gauge on it to see what its doing.Could be the regulator.
Old 12-15-2013, 06:54 PM
kelsey_canard's Avatar
X2. do a fuel pressure test. That will help you diagnose your problems.
madmann26
04-29-2020 09:17 AM
dsbodley
11-14-2015 09:46 PM
2002_Z28_Six_Speed
10-04-2015 01:34 PM
blackedoutchevy22
10-01-2015 08:07 PM
02AWDAWSDenali
10-01-2015 05:08 PM
Quick Reply: Walbro 255 problem, need help
