vette filter issues
#23
I just installed the racetronix kit with a hotwire set up and it was fast and simple. I would recommend it for sure. You will need the extra pump with your mods so I would go ahead and do the swap.
Not sure how you can mess up a closed loop tune. Especially if you are charging $550
#25
now yes i did just shove the filter onto the square rails and hook up the fuel lines and you are correct it does not work that way. looking back i have made alot of rookie mistakes but that happens to everyone i guess. now how do you do this the right way to not get kinks? am i going to have to suck it up and build my own hoses from the factory filter up? is there a company that makes the hoses i can just buy? im at a point where im getting overwhelmed with little **** and im getting burned out quick.
#26
i am planning on fixing it asap though.. you could just cut back the ends off of the lines by the firewall and buy some fuel line to slip over them and attach the ends u cut off to the filter to the hoses... might not look the best but would un kink it...
wonder what everyone else has done...
#27
so no one has a vette filter installed without kinking the hose? someone put up some pics i would like to see how you did it.
on another note pulled the plugs from the truck and all 8 are white. he has this truck tuned so lean i dont know how its running. called visa and filed a claim against Nick at Newtech and got 450 of my original 550 back.
#29
I mounted the filter further up on the fuel rail with a vynl cable clamp. And looped a line back into the rail. Cant seem to get pics to up load. I'll keep trying. there you go.
lucas287
31
01-12-2021 06:18 AM
murderedSS
27
10-12-2015 11:13 AM
MA$TER_E
09-09-2015 03:14 PM
