Upgrading fuel system questions
Old Jul 30, 2015 | 11:46 AM
MS3Z's Avatar
Default Upgrading fuel system questions
I'm going to be upgrading my fuel system soon. I've been searching threads for the last week and I'm getting a little confused. The truck is going to need a fuel pump and injectors. It's a 2002 4.8 with a Whipple side mount and meth at 10psi, a cammed 5.3 with the whipple is coming soon. It still has the electronics from Whipple but I'm going to get rid of them when I install the injectors and pump. I'm getting confused on what pump to use and all the return and returnless stuff. I was going to buy 42lb delphi injectors for now but I would rather have 60's. Eventually I want to put down around 500. Will a walbro 255 and 42's be enough for that goal? If not what 60lb injectors would work? What plugs are on the stock injectors?
Old Jul 30, 2015 | 01:47 PM
Wrecker 426's Avatar
call the guys at fuel injection connection. they will talk your ear off on what you need to get. Ask for the owner though.
Fuel Injector Connection
also look at atomic's, fuel flow sticky and download the excel and put what injectors in then it adjust the charts and will answer
https://www.performancetrucks.net/fo...p-flow-510434/
FWIW BB said that i would be fine but maxed out on a walbro 255 and 62/lb/hr and 10 psi 5.3. so im going with a 450
If you want just a 255 racertonix sells a drop in kit, email them a vin and they will make the right kit
Racetronix - FPM-007 - Fuel Module, GM SUV, High Perf. Type 007
Old Jul 30, 2015 | 01:55 PM
MS3Z's Avatar
I was looking at the racetronix module but I'm not sure if the 255 is enough because I don't know what I'm going to do with the truck. I may get rid of the whipple and do a stroker so I would like to just put a pump in that I won't have to worry about changing down the road.
Old Jul 30, 2015 | 02:16 PM
MS3Z's Avatar
How would I go about installing a larger walbro pump say a 450?
Old Jul 30, 2015 | 02:25 PM
https://www.performancetrucks.net/fo...nstall-529510/
How To: Walbro Fuel Pump In 2003 Silverado Ss - How To - SilveradoSS.com,
Most seem unfinished or not that detailed when you find a write up about it. SO that makes me believe that its alot easier then i think it is. Also talking wit ATOMIC, (sorry if im throwing you under the bus atomic but you got lots of good info), basically swap the pumps run the fuel line and run new 10ga wire all the way back from the relay, and new 10ga ground. The 99-02 have smaller pump buckets, so some poeple switch to a 03-newer bucket and run a return system.
Old Jul 30, 2015 | 02:30 PM
thewrx's Avatar
yeah those injectors get expensive quick with you look at the 100+lb ones.
Old Jul 30, 2015 | 02:50 PM
MS3Z's Avatar
Expense really isnt an issue I just don't want to buy too small of one's and have to upgrade later. I'm just not sure which ones fit.
Old Jul 30, 2015 | 05:21 PM
gamble686's Avatar
The aem320 is pretty legit, inexpensive, and a nice middle ground where it shouldn't overpower your fuel pressure regulator. The 450 is almost for sure going to over power the regulator.
Old Jul 30, 2015 | 06:17 PM
its a 2007 but same way to acces without dropping or completely removing bed
Pt.1 2007 Chevy Pickup Fuel Pump Replacement At D-Ray's Shop - YouTube[/ame]"]
Rafe19
Oct 18, 2016 12:27 AM
D1SCSS
Jan 25, 2016 10:14 PM
lxcoupe
Jul 21, 2015 02:12 AM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
4B11T
Jul 13, 2015 03:48 PM
