Stock Pump Enough for Heads/Cam Setup?
Old Jun 12, 2012 | 07:27 PM
Slow94Formula's Avatar
Default Stock Pump Enough for Heads/Cam Setup?
Working on putting a 02 lq9 into an 03 RCSB truck that has a 4.8 in it currently. The setup will be stock bottom end 6.0 with LS3 heads, L92 intake/injectors, and the cam will be 222/230 .597/.600" 114LSA +2. planning to make around 450, hopefully more (through an auto). lol
What are the limits of the stock fuel pump? Also, will the stock l92 injectors be enough to fuel this setup?
Old Jun 12, 2012 | 09:17 PM
Sn0wBa11's Avatar
11 Second Truck Club
If you expect to make 450rwhp then yes you will need a pump. The walbro 255 F20000169 is a good in tank pump that requires minor mods to the fuel bucket to work.
Old Jun 13, 2012 | 09:14 AM
Sales3@Texas-Speed's Avatar
Truck Sponsor
We offer a Racetronix in-tank upgrade kit just for this that includes the Walbro 255
Texas Speed and Performance - Racetronix In-Tank Fuel Pump Upgrade Kit
Old Jun 13, 2012 | 02:26 PM
Thanks guys!
Another question that was brought up...Will L92 injectors plug right into the stock harness or are adapters are needed?
Old Jun 13, 2012 | 05:18 PM
darnie's Avatar
i may end up getting one of these... im pretty sure im getting close if not already there with my mods.
Old Jun 13, 2012 | 05:49 PM
Truck Sponsor
Originally Posted by Slow94Formula
Thanks guys!
You will need to get adapters or splice in the correct connector.
Old Jun 13, 2012 | 05:50 PM
Would you be so kind as to link me to the correct ones?
Old Jun 14, 2012 | 02:46 PM
Planning on making an order soon if I hear back about what adapters I need to use... I did some research and think I need the minimeter to uscar adapters, but want to make sure that's correct before I order.
Old Jun 14, 2012 | 02:57 PM
AndysC3's Avatar
I bought a fuel pump assembly from Racetronix. All I had to do was replace the whole assembly. Didn't have to mod the bucket at all.
I'm using the marine 8.1L 42# injectors. Plugs right in.
Are you wanting 450 at the crank or at the wheels? To the wheels might be pushing it a little.
Old Jun 14, 2012 | 03:40 PM
Pretty sure 450 rwhp won't be too hard to hit with a cammed 6.0 and LS3 heads. The cam specs above have hit 517 rwhp with a t56, LS3 heads, and a car intake. Don't think the truck intake will be that far off. Obviously expecting different numbers since the truck has an auto and a different intake.
