severe fuel pressure drop after pumps swap
Old May 17, 2016 | 01:43 PM
supercharged680's Avatar
Default severe fuel pressure drop after pumps swap
Hey guys, i swapped my 255 walbro fuel pumps with 400's , now the fuel pressure goes below 40 as soon as it sees boost, any idea what could be the problem? i replaced the hobbs switch and nothing changed. fuel filter is very old but i doubt that is the issue.
Thanks
Old May 17, 2016 | 02:49 PM
Atomic's Avatar
I have a gauge for that
-Electrical problem with insufficient wiring
-Regulator not boost referenced
-Second pump not turning on
-Fuel line inside the tank is leaking
My money is on the last one.
Old May 17, 2016 | 03:13 PM
Three6GMC's Avatar
Same here think you need to check fuel lines in the tank. Seen that happen plenty of times. After that you confirmed that lines in the tank are good check the Hobbs switch and verify the second pump is coming on.
setxathlete14
Sep 26, 2016 04:36 PM
D1SCSS
Aug 29, 2016 11:21 PM
Thoagland
May 26, 2016 09:14 AM
cj847
Apr 26, 2016 06:54 AM
Go5.3tt06
Mar 21, 2016 05:52 AM
