Returnless rails work for return coversion?
Old May 20, 2016 | 02:32 PM
MikeD.'s Avatar
Default Returnless rails work for return coversion?
Can I use the stock returnless rails when I convert over to returnstyle? Or I MUST go aftermarket?
Old May 20, 2016 | 10:39 PM
GMCtrk's Avatar
You can, but you will have to put the regulator on the feed side which is not ideal.
Old May 21, 2016 | 06:30 PM
MikeD.'s Avatar
What aftermarket rails are people using on the NNBS intakes?
Old May 21, 2016 | 09:57 PM
TrendSetter's Avatar
i used a stock rail with an aftermarket regulator with great success. i wouldnt spend the money on aftermarket rails if thats your only reason.
Old May 22, 2016 | 08:02 PM
MikeD.'s Avatar
Is there a specific regulator that I need to use the factory rails?
Old May 22, 2016 | 08:36 PM
no, any regulator will work. you just need a special fitting for the rail to convert to an lines.
Russell Push-On EFI Fittings 644120 - Free Shipping on Orders Over $99 at Summit Racing
ive had good luck with aeromotive regulators, but my decision to buy that brand was pretty arbitrary.
if you use stock fuel lines you can get these adapters for those
Russell Fuel Rail Fitting Adapters 640930 - Free Shipping on Orders Over $99 at Summit Racing
Russell Fuel Rail Fitting Adapters 640940 - Free Shipping on Orders Over $99 at Summit Racing
basically you get a return regulator with at least two inlets and one return port. run the stock feed into one of the regulator inlets, then the other inlet port you route to the fuel rail inlet. the return port on the regulator then goes to the stock return line to the tank.
Old May 23, 2016 | 12:26 AM
MikeD.'s Avatar
Awesome that helps so much. Any insight on removing the fpr and such in the bucket? Should I just pull the complete regulator and filter assembly out of the module, or just leave it in the there and just bypass everything by running a new fuel line right off the pump to a new -6 bulkhead through the top of the pump housing?
Old May 23, 2016 | 11:39 AM
i cant help you with that, but im sure theres a way to bypass the internal regulator with a plug of some sort, ive never seen one in person
Old Jun 6, 2016 | 08:34 PM
MikeD.'s Avatar
Started my dead head return install, I know everyone was staying I need to have the regulator as close as possible to the rails. Right now the closest I can get it is near the booster, with about 7/8" of addition fuel line off the regulator before it hits the rails. This acceptable?
Old Jun 6, 2016 | 08:40 PM
i ran my aeromotive regulator on the frame rail of my s10 near the tank. it worked fine. ymmv
