Returnless Maggie to Return Setup
except
99-03 GM Truck Fuel Manifold Magnuson Superchargers RETURN STYLE [MAG-31-12-00-010] - $125.00 : SuperchargersOnline, Worlds largest Supercharger Resource. Get Serious About Power
That should be all you need if you already are on a stock return setup. Lookup some Maggie instructions and see what port is what for the manifold block or start blowing it like Richard said.
I'll give it a good blowing when it arrives in mail.
I'm figured someone would of said it already but your probably going to keep upgrading with more boost and more fuel and over power that stock regulator. Why not just collect the parts and plumb in a boost referenced regulator. It will cost more and be more work but it will be done for when you upgrade to a bigger pump. Or do you plan on just getting it running and go from there..?
