returnless fuel pump
Pumps that are advertised as 255lph are called that because they flow that amount at a specified pressure. Once installed in a module/system the actual output @ that pressure is less than 255lph.
The pump used in that module is a F90000267 which translates to what is commonly called a "Walbro 450"
I don't suggest running a 450 on stock wiring. Those are some horrible losses through a filter. Yes a 267 is a 450, I have a couple.
Just swapping a pump is extremely easy if your module is in good shape. If the hat is rusted or something then that's different I would replace it.
Also the bucket filling jet or Venturi relies on post regulator fuel, meaning at high fuel demand it does basically nothing as it only uses fuel the regulator by passes.
The unit offered by Holley is a complete drop in with an in tank regulator built into it just like the O.E. module with the set point at 58psi.
They are rated for 500hp, that is what they can support while maintaining bucket fill.
