Returnless 450
Un-Registered User
I bought this and actually called them before hand. I asked if it was really a "drop in" they say yes, I have lots of doubts because it's been tried on here a lot. Either way, for the price, it is a genuine pump and comes with the correct type of fuel line needed (not the rubber type). My truck is a 07NNBS though and haven't installed it in the bucket. The one thing for me is that it does not have the second port for the Venturi. I will have to figure out how to fill the bucket without coming off the pressure line for the Venturi. This will be my project for next week.
I was able to keep idle pressure in line with the venturi mods as Pat mentioned. The problem was that the returnless system limited the capability of the 450 pump in a major way. I lost fuel pressure long before the pump was capable of pushing through a return system.
Take it from me, someone who has been there, its worth going return style.
The Holley 12-954 comes with a Walbro 450 / F90000267 pump. It is called out as a 255LPH pump on because it is only rated for NA - 550hp. This module is produced by TI Automotive who bought Walbro 15 years ago.
This horsepower rating is limited by the refilling jet/venturi system not the avaliable pump output.
I bought an aftermarket chinese returnless module on ebay. Removed the pump, regulator and filter. Installed the 450. Gonna run it through a fuelab regulator located near the tank with a return on top (bulkhead fitting) into the bucket. Post pump filtration through a spin on filter. Hot wired of course.
Can't see how it won't work. Ill let you know in a week or 2...
