Pump help plz!!!
Old Feb 6, 2014 | 06:55 PM
La Grey 1's Avatar
Default Pump help plz!!!
ok guys im looking into buying a fuel pump for 5.3 im getting ready to install a turbo kit and my goal is 500-600hp at the most when im done with it which pump will get my goals and last some miles on my dd... im looking into the walbro 450 or 400 i have read about the fuel pumps but what do u guys recommend
-can the 450 work on 93???
-another question, i have a fuel regulator and return lines and want to keep my stock feed for now what are you guys using as a filter or what fittings do i need to tap on my stock feed line to add a filter??
any help is appreciated
Old Feb 6, 2014 | 07:39 PM
oakley6575's Avatar
I would run the 450. Why do you want to add another filter? Why not just keep the stock filter if your keeping the stock lines??
Old Feb 6, 2014 | 07:48 PM
La Grey 1's Avatar
so the 450 isnt really for e85 use only i can run it with whatever i decide to use??? and my truck is a 06 so my filter goes in the bucket thats why i want to remove the stock one and add an external one outside like the 99-03
Old Feb 6, 2014 | 07:55 PM
oakley6575's Avatar
Oh you're just talking about the pump sock. It is just a pre filter for the pump. Just buy a sock for the 450 pump and put it in the bucket like stock. Why do you want it outside of the bucket like the 99-03?
And yes, it is designed to run pump gas but is rated for E85 as well. You'll be fine.
Old Feb 6, 2014 | 08:14 PM
La Grey 1's Avatar
i get you but i have seen people run filters aside from the sock or will the sock be sufficient to keep the fuel clean im a little lost here and dont want to take it apart with something missing
Old Feb 6, 2014 | 08:29 PM
oakley6575's Avatar
I guess I don't understand how your thinking about doing it. How would you run an outside filter without anything on the pump?
I would just run the sock, and the stock in line fuel filter.
Old Feb 7, 2014 | 10:30 AM
La Grey 1's Avatar
bump...
Old Feb 8, 2014 | 08:55 PM
Convert to the return style rail like your planning and use the 400 or 450. Add an inline filter like the factory 99-02 trucks have. Go ahead and get the 80lb injectors while your at it.
Old Feb 8, 2014 | 09:28 PM
oakley6575's Avatar
Wait what? The 04-up trucks don't have an inline fuel filter?
Old Feb 9, 2014 | 01:16 AM
La Grey 1's Avatar
no they dont lol... and i have some 60lb injectors i got for a good price so i had to pass the 80s... the question is how do i add the inline filter to my stock feed line
