Post Your E85 Set-ups
Old Jun 16, 2012 | 08:41 AM
  #21
03regcab sierra's Avatar
For mine i was thinkin of using a single a1000 pump with the fic 1000s. Not sure if im gonna run -8 or -10 fuel line to the rail yet and also use billet rails and aeromotive 1:1 regulator
Old Jun 16, 2012 | 01:25 PM
  #22
SLO TRUCK's Avatar
Not Tested yet but system is ID 1000's, Aeromotive FPR, Aeromotive Eliminator pump, -10 feed Y'd to -8 at the front of the rails then Yd at the back of the rails to FPR and a single -8 back to the cell. . We will see where the id1000's get me but might need more injector. Hope not.
Old Jun 17, 2012 | 01:47 AM
  #23
Pc2000trk's Avatar
Running two 340lph pumps y'd into -8 feed returne -6 , aeromotives's boost reference regulator , billet 1/2" rails 103lb inj - 30amp relay for each pump
Old Jun 17, 2012 | 03:21 AM
  #24
slowec's Avatar
You guys are turning this thread into a useful one. THANKS!!! I hope you will report back on some of this setups with results. It looks like if I wanna run a cammed 6.0 on the corn juice I will need an entire overhaul ti my current system.. durn-it .
Old Jun 17, 2012 | 03:49 AM
  #25
AKlowriderZ71's Avatar
11 Second Hall Moniter
Originally Posted by sprayedenali
im at 75psi base pressure right now, probably gona bump it to 80 soon, but then i cant go over 20psi bosot before my regulator runs out (only good to 100psi) but that should be fine. im running 17psi now FWIW.
RustyD
May 23, 2016 07:04 PM
dsbodley
Nov 14, 2015 09:46 PM
Wrecker 426
Sep 29, 2015 11:00 PM
