Post Your E85 Set-ups
Old Jun 15, 2012 | 06:32 AM
slowec's Avatar
Default Post Your E85 Set-ups
I will eventually build a fuel system to support the all mighty corn liquor. Please let us wanna be e85 folk what it takes. I am thinking Two walbro e85 400's , -8 , aftermarket rails, 103lb injectors, aftermarket regulator, stock feed as return. Feel free to tell me where I am right or wrong.
Would love to hear how people already running it made it happen.
THANKS
Old Jun 15, 2012 | 07:33 AM
LS1FREEK's Avatar
13 Second Truck Club
Subscribed
Old Jun 15, 2012 | 08:35 AM
TimDave217's Avatar
i'd also like to know what people are doing with there e85 setup's. more so what injectors people are using in 700-800 rwhp setups. I'm thinking the FIC1000's will do justice?
sprayedenali's Avatar
20 gallon cell with two -8 outlets into two Bosch 044s with a -8 outlet on each then Y'd into a single -8 up to the rails and Y'd again in to two -8s going into the back of each rail then out the front into a aeromotive 13101 regulator with a single -8 return to the cell and 120lb @ 43.5psi injectors. Persevere seems to be holding steady but injectors are maxed out and I'm running a 75psi base pressre
Old Jun 15, 2012 | 10:17 AM
slowec's Avatar
Thanks for sharing! time for 160's ??? on a 5.3
What intake are you running? dare I ask for a pic?
Old Jun 15, 2012 | 10:42 AM
nonnieselman's Avatar
are those 120s low or high impedence?
Old Jun 15, 2012 | 11:41 AM
TX Tahoe Z71's Avatar
Slowec, got your PM, but I'll post up here for the benefit of anyone else looking at going corn-fed.
I am a stock 5.3 flex fuel, so it has a fuel sensor detecting the mix of gasoline to E85 and Wheatley set up the high octane tables to adjust based on those sensors. I don't think HP Tuners lets you adjust the E85 tables yet, but I believe EFI Live does. But there is a night and day SOTP difference between 93 and E85 now, probably 40-50rwhp according to my butt dyno. Also, by law I believe that E85 has to be minimum 70% ethanol (not necessarily 85%), so be careful with tuning as the Kroger I use Wheatley read at about 72% ethanol.
My fuel setup is pretty basic. I have a return-style system with the stock flex fuel pump (that flows about 260gph according to Jon at FIC), boosted by a 20A Kenne Bell Boost-a-Pump triggered at 3psi. The injectors are Ford Racing Ford GT OEM injectors (part # M-9593-G302, EV14 body style, USCAR connector, 47lb at 39.15 psi, 6-hole, high-impedance) opened up by Jon at FIC to flow 75# at flex fuel pressure, 47 psi IIRC, and spray pattern narrowed for a 2V engine vs 4V to reduce wall-wetting. They were drop in with no spacers for my truck, but I do not know if the NNBS FF injectors are the same.
This is going from memory when Wheatley tuned it for E85 a while back, but I believe WOT timing was in the high 20's and cruise was around 42-44*. My mpg did drop from 11.5-12 in the city to around 9, even with the added timing at cruise. He spent a while trying to milk it for all the mpg it was worth, but that's all it had. I am still on the MAF so he can't command lean cruise, but OLSD might have some better results. In Houston, E85 costs about 20% less but mpg is about 30% worse, so it still costs more to run E85 overall. Congress also let the $0.45 ethanol subsidy expire, so that has brought the price of E85 up.
Old Jun 15, 2012 | 11:54 AM
idahoblkss's Avatar
i got 2 walbro 255's that y off into a -8 line into ls1 billet rails into a aeromotive regulator with a -6 return . running 80# SIEMENS DEKA that are maxed out but thankfully for the regulator it is allowing me to press on with it being 1:1 . i need to get some id2000 injectors and be done with it, im so tired of upgrading injectors at this point lol this is my 4th set of injectors . i dont know what power im at 6-700 range ?? but im running 16#'s on e85 . so if your going to go the e85 with big power route plan for the biggest you can buy with the fuel system 100+ # or cut to the chase and get id2000 injectors and 2 044 pumps would be the way i would do it if i had to do it again.
Old Jun 15, 2012 | 01:12 PM
Yup, gona try to get some 160s soon. Yup, stok 5.3 with a baby cam. Pro flo intake. High impedance. There the bosh racing 127s from FIC. I'll post a pic when I get to a computer. Or look on my face book, there's a few
Old Jun 15, 2012 | 01:18 PM
what injector driver box you running?
