nnbs fuel system solution
Old Mar 9, 2015 | 08:41 PM
turbo truck's Avatar
Default nnbs fuel system solution
Im thinking the solution for fuel with my nnbs. Just curious to know if anyone has used a Aeromotive 18309 - Aeromotive Phantom Stealth Fuel System one of our trucks. Rather than try to jimmy a system together Im going to put this in my truck. Im going to use the current feed line as a return and put a regulator on. I was close to using a sump and a single external pump but the cost was close to the same and It seemed to have 2 draw backs one being the noise and 2 being the heat on the pump.
Old Mar 10, 2015 | 10:03 AM
ncarmy88m's Avatar
Do IT!!!! Those are great pumps you won't regret it
Old Mar 24, 2015 | 06:21 PM
Default pump not in
I Ordered the system at the same time as the post, unfortunately It has still not Arrived. When I spoke to the manufacturer today they confirmed that the reason my order hasnt been shipped is because the parts are back ordered and the date that I was given previously would be pushed even further back so that they can manufacture a new batch. I will post updates as soon as the parts arrive just in the waiting game right now.
Old Mar 24, 2015 | 06:37 PM
03sierraslt's Avatar
A lot on this site have had issues with the Aeromotive 320 pumps failing prematurely. Just a fyi.
Old Mar 25, 2015 | 07:08 AM
Default 320 is aem
I believe AEM is the manufacturer of the 320 pumps. The Dual phantom is produced by Aeromotive and has their 340 stealth pumps installed.
( are they the same product?) I am not going to use the Stock fuel system , New appropriately sized wiring , will not be using the stock fuel controller.
Old Mar 25, 2015 | 09:20 AM
Atomic's Avatar
I have a gauge for that
I wouldve bought a walbro400 or 450 personally. Could have it next day via amazon. I am not a huge fan of those aeromotive pumps (the larger ones are fine).
Old Mar 25, 2015 | 10:04 AM
George C....'s Avatar
Formerly ScreamingL
depending on power looking to make a FF supports quite a bit of power
Old Mar 25, 2015 | 09:21 PM
The reason I went with this kit was not for the pumps, I was looking at options to add a return on my nnbs and this kit gives me the option to add the fuel i need but to not have to hack together my stock pump housing and to have a cup at the bottom to help with sloshing ect. I felt like my Only other option was to do an external a1000 with a fuel sump cut out in the bottom of my tank, the negatives for that kit where noise and reliability for daily driving.
RONIN LSX
Aug 10, 2015 04:45 PM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
