Flex fuel injector plug?
Old 03-26-2015, 05:58 PM
Custm2500's Rude Friend
1FastBrick's Avatar
Default Flex fuel injector plug?
By any chance does any one know what style of plug the Flex fuel trucks use for the injectors???
Old 03-26-2015, 06:10 PM
Three6GMC's Avatar
mine uses EV6
Old 03-26-2015, 06:21 PM
skolman91's Avatar
Not sure what you're trying to do, but five o motorsports sells adapters ev6 to multec II, i used them on my last truck to run flex injectors..
Old 03-26-2015, 06:39 PM
1FastBrick's Avatar
My 06 truck is a flex fuel equipped truck and I need larger injectors for a new project.
I can order the larger injectors with what ever plug end I need. I have to specify which plug as they don't know which one it has or have that info.
I also need to change the injector plugs on the stand alone harness for the engine Dyno.
I would rather not have to buy a bunch off adapters since the plug style can be had on the injector at no cost.
Thanks for your guys help.
Old 03-29-2015, 02:46 PM
Restricted
JordanH's Avatar
If your injectors and plug look like this, you have the ev6/ev14 style. If you have a small plug that doesn't look like this you have the multec II Delphi mini style injectors. Hope this helps!
RONIN LSX
08-11-2015 12:03 AM
05GMC4.8
08-07-2015 09:55 PM
RS/SS 4.8
08-02-2015 11:03 PM
lsxmalibu
07-29-2015 07:08 AM
blackdc3
07-07-2015 07:52 PM
Quick Reply: Flex fuel injector plug?
