Low fuel pressure with Walbro 450
Old 01-25-2016, 06:18 PM
BlueTexan24's Avatar
Default Low fuel pressure with Walbro 450
I just installed a new Walbro 450 with the hotwire kit since my stock pump died and went to put a pressure gauge on it to see just how high the pressure is and try to adjust it down some until I get an aftermarket regulator and for some reason it's actually low. the gauge read 48 with and without the vacuum line on. I turned the screw on the FPR all the way in and out to no effect. Then revved it up in park and the pressure went down to 40ish. I'm not sure what it could be besides the filter possibly? Has anybody else had this problem?
Thanks guys.
Old 01-25-2016, 07:34 PM
I have a gauge for that
Atomic's Avatar
Possibly filter, bad electrical connector, or leaking hose inside the tank.
Old 01-25-2016, 07:48 PM
TrendSetter's Avatar
I had my aeromotive regulator get stuck open internally so pressure was really low cause it was just bypassing all the fuel. i pinched the return line to force higher pressure and it came free and started working right again.
I still took it apart and cleaned it all after though.
Old 01-25-2016, 08:12 PM
Sweet. I'll try pinching the hose and see if that works. I bet it may be the hose in the tank though because it doesn't hold pressure when I prime it
Old 01-25-2016, 08:19 PM
if the regulator is stuck open it wont hold pressure. give it a shot..might be a free fix
Old 02-06-2016, 11:27 AM
Thanks guys, it ended up being the line inside the tank.
Rise of the Phoenix
01-20-2016 01:01 PM
roland1
01-04-2016 09:00 AM
Steve Bryant
01-03-2016 11:16 PM
BimmerTech04
12-30-2015 01:08 PM
TAPyvehc93
12-28-2015 08:28 PM
Quick Reply: Low fuel pressure with Walbro 450
