Low fuel pressure issue
several people run a t fitting. All if the y fittings that I have found are at a 120* angle and wouldn't be much better. That fitting from summit is nice but I'm not going to spend 25+ the other fittings for it
Its $33.14 for the Y and 3 Hose ends.............................................. .................................................. ................................. .................................................. .................................................. .................................................. ................
Personally, I'm not convinced the 90 degree fitting was the cause of your failure. I would NOT use those worm gear clamps. They tear into the hose and that could have initiated the failure which was exacerbated by the angulation of the hose. If you notice the tear starts up where the clamp is. Instead use Oetiker clamps.
Just because people run the hose like that doesn't mean it's right . That's really hard on that pump deadheading like that .
BlackGMCs bucket is how it's done .
Take your time and redo that abortion in your bucket . Then you shouldn't have any problems .
