long cold starts
Old 12-20-2013, 09:04 AM
GMC93's Avatar
My 2004 Tahoe did the same exact thing until i replaced the fuel pump assembly. Check Amazon for a cheap OEM Delphi fuel pump.
Old 12-20-2013, 11:57 AM
69Camaro427's Avatar
I would try the plugs before the pump. What is your game plan on removing the broken header bolts? Take the heads off?
Old 12-20-2013, 12:18 PM
Resident Retard
BlackGMC's Avatar
Originally Posted by TIM Z
X2 stew put a walbro 255 in there and call it a day , hard to find a better pump especially for the money .
And damn dude put some plugs and wires on that bish !
I recommend the walbro 255 as well. That is what i run and what i have always ran. No problems. Just make sure you get one with the check valve.
Old 12-20-2013, 12:48 PM
11 Second Hall Moniter
AKlowriderZ71's Avatar
Stew, do you have a fuel pressure gauge? If you can, get it on there for a cold start test. I'd bet that your pump is weak & building pressure really slow.
Old 12-20-2013, 01:31 PM
Chevy_King1500's Avatar
i bout an airtex fuel pump assembly for my truck back in the day. it worked good.
Old 12-20-2013, 02:24 PM
TXsilverado's Avatar
for you guys swapping to a walbro 255, what are you using to connect the pump to the bucket? i've heard of stories of rubber line cracking and swelling. GM uses that plastic **** that seems to heat shrink on
Old 12-20-2013, 03:13 PM
Resident Retard
BlackGMC's Avatar
I have a bunch of the plastic hose in a ton of different sizes. For clamping it goto home depot in the plumbing isle and get some pex compression clamps. I can mail you some hoses if you want.
Old 12-20-2013, 03:27 PM
gss340 is he wabro PN that will work for an 02 HD right? i'll just order some submersible fuel line from summit when I order the pump
Old 12-21-2013, 05:25 AM
11 sec. Truck Mod
TIM Z's Avatar
Yup like Corey said you can use the plastic corrugated line and otiker clamps ,
Racetronix sells them also.
I like using them instead of hose just because that's what the factory did and I've never had an issue .
Yes the 255 fits nice in the factory bucket .
Also good call Corey on getting the one with the check valve , it's been a while and I forget which part# that one is .
Old 12-24-2013, 06:59 PM
are the 255s noise? and the check valve keeps the pressure up when the motor is turned off for the next start?
Quick Reply: long cold starts
