L76 in a 01 Yukon
Old Dec 11, 2014 | 01:09 PM
Pro52R's Avatar
Default L76 in a 01 Yukon
Ok,i know the fuel rails etc are different, i was going to retrofit my 01 rails with return for the L76 intake. What injectors will i need? EV1 EV6?Can i use the older injectors and just use spacers on the rails? or do i need different injector connectors anyways? and for a cammed L76. 42lb should be enough?
Old Dec 11, 2014 | 03:12 PM
Vortec350ss's Avatar
42lbs will be enough. Your truck is an EV1 connection, and you shouldnt have a hard time finding EV1's that fit those rails and manifold. If not the new harnesses are cheap and an easy swap. Is the L76 flex? If so the injectors that are on it should be enough for gasoline.
You will need something to let your PCM read the 58x reluctor on the crank.
Old Dec 11, 2014 | 04:27 PM
Pro52R's Avatar
I'm swapping reluctor wheels. I only have a short block currently. So building it as I go. EV1 is what is on the 97+ LSx? Aren't the trucks some kind of weird connector?
Old Dec 12, 2014 | 12:37 AM
I'm curious what it costs to do a reluctor wheel swap.
Old Dec 12, 2014 | 12:54 AM
Pro52R's Avatar
Some local shop $50. Wheel is only $17.
calsdad
Jun 14, 2023 11:07 PM
Go5.3tt06
25
Sep 4, 2016 10:25 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
mayko
Sep 7, 2015 12:24 PM
