internal and external pumps FOR BOOST
Old Apr 28, 2014 | 10:18 PM
Mortiz's Avatar
Formerly PurplePearl (2014-04-06)
If you could get some pictures I would appreciate it!
Old Apr 29, 2014 | 10:03 AM
Denali08's Avatar
Originally Posted by joeyc125
Drilled a hole in the rear. The pump only runs when I'm above 5psi, and the back of the tank is where all the fuel will always be at that point. I could take a pic sometime if you want. Think I tapped the hole for 3/4 pipe and used some epoxy also. Never leaked or had any issues.
Did you use a bulkhead fitting to connect to the tank?
Any part numbers for the fittings?
Old Apr 29, 2014 | 07:01 PM
LsF-150's Avatar
I did the same thing for my return line into the top of the tank. Granted it is only holding fuel back when the tanks full but hasn't leaked a bit. Magnafuel MP-3014, it has an o-ring and rubber gasket, worked well.
Old Apr 30, 2014 | 11:34 AM
joeyc125's Avatar
11 Second Truck Club
Haha, no I didn't use a bulkhead fitting. I would recommend it if you have access to the inside of the tank. I just used a brass reducer fitting from home depot. 3/4 pipe to 1/2 pipe with a hose barb fitting. Like I said, it's never leaked and has been in there for about 4 years. The plastic is pretty thick on the tank. Gives you some good material to tap into.
GXPJAY
Feb 13, 2022 08:15 AM
05GMC4.8
Aug 7, 2015 09:55 PM
lxcoupe
Jul 21, 2015 02:12 AM
ullose272
11
Jul 17, 2015 07:22 AM
