Inline fuel pumps
Old Nov 1, 2013 | 02:34 AM
gamble686's Avatar
Default Inline fuel pumps
So I know this may be a stupid question especially coming from me, but I really don't understand why people don't run inline pumps. It seems to me like it would be a lot easier than the hassle of dropping the tank. I get that it's louder, but besides that? Please educate me.
Old Nov 4, 2013 | 01:11 PM
Atomic's Avatar
I have a gauge for that
Because it only allows the pumps to operate at a low pressure meaning the only difference in volume is going to be what a pump flows at half its normal pressure. A fuel pump might deliver 80% of its 0psi rating at 60psi, so if you run 2 pumps of the same size inline they each operate at 30psi, so 90% rating. So basically 2 pumps for only 10% more output.
Now if you install two pumps in parallel and not inline, you have twice the output, so a 100% increase in fuel.
Old May 18, 2014 | 08:24 AM
Badasschevillac's Avatar
Why couldn't you do a Y in your feed line and run 2 pumps and then Y is back down to 1? Is that the same as the parallel you stated above or no not the same concept?
Old May 18, 2014 | 09:10 AM
Atomic's Avatar
Thats parallel. Inline is when the entire flow of one passes through another pump.
Old May 18, 2014 | 09:52 AM
so one could in-turn do what i stated?
Old May 18, 2014 | 10:02 AM
Atomic's Avatar
Sure, thats what almost everyone does. The only difference is where you put the Y. Most do it in the tank so you only see one feed line coming out.
Old May 18, 2014 | 10:14 AM
so you could do it on the frame rail right?
Old May 18, 2014 | 11:43 AM
MikeGyver's Avatar
The problem with external pumps is keeping the fuel pickup in the tank covered with fuel when accelerating, slowing, and not so much in trucks, turning. Also, most pumps lose a lot of capacity when they have to do any sucking whatsoever, so gravity feed with a large hose is preferred. If you can meet these criteria, you'll be OK.
Old May 18, 2014 | 03:43 PM
Ok I understand now. I have been reading a lot about the "keeping 1/2 a tank of fuel problem" so it makes sense now. I never really thought that would be a problem but I thought wrong. Thanks everyone for the replies. I understand why everyone is concerned about going with a sump in there cells.
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
