injector size ?
Old Aug 3, 2016 | 10:16 AM
turboal1's Avatar
Default injector size ?
I Need to know what size the inj's are on a
2011 Silverado 6.2 L9H flex fuel eng. so i can fix my tune.
9.5 mpg sucks.
also do you think i should swap to a LS3 90mm T/B since i installed a bigger cam ? It has a 87mm now.
The truck has DT long headers,CAI and a 2500 stall, 3:73 gears, dual e-fans
Old Aug 3, 2016 | 10:31 AM
FFDP's Avatar
You can find a 2011 6.2 V8 tune on the HP tuners repository and get you injector information straight from there. That would be the easiest way because everything you need will be there.
My personal opinion would be if you can't outflow the stock size TB yet, don't upgrade but that's just what I think.
Old Aug 4, 2016 | 10:51 AM
turboal1's Avatar
Default no password
I don't have HP Tuners, I can't get in. I am trying to get the info for my tuner.
to make things go faster. we think they are 38.5 lbs
Old Aug 4, 2016 | 11:05 AM
FFDP's Avatar
If I am reading right and doing the conversion right they are 43lb/hr at 3 BAR and 50lb/hr at 4 BAR.
Stock 5.3 flex fuel injectors are 33lb/hr at 3 BAR and 37-38lb/hr at 4 BAR.
johnnymart610
Aug 26, 2017 02:31 AM
setxathlete14
Sep 26, 2016 04:36 PM
setxathlete14
Feb 22, 2016 08:38 PM
Turbo6.0
Feb 19, 2016 03:17 PM
Ryan23silverado
Jan 19, 2002 12:53 AM
