Injector size??
Old Nov 19, 2014 | 09:46 AM
zaathur151's Avatar
Default Injector size??
I have been back and forth on what size injectors to get for my setup I have a stock Lq9 with a 222/224 .566 .568 112LSA cam with 74mm front mount turbo with stock intake with 91 gas, my normal boost will be 8psi -12psi max?
Old Nov 19, 2014 | 10:52 AM
gamble686's Avatar
60s should be just fine and are simple to tune, but might be a little close depending on fuel pump and pressure. 72s if you don't mind spending a little more. I wouldn't go much higher than that unless you have an excellent live tune. The 80+ Injectors have a tendency to need a little more fine tuning.
Old Nov 19, 2014 | 12:31 PM
zaathur151's Avatar
I will be running a single walbro 255 or 400 with factory fuel regulator return style
Old Nov 20, 2014 | 08:38 AM
slowec's Avatar
400 will overpower your stock regulator.
Old Nov 20, 2014 | 02:51 PM
cwalker2006's Avatar
I have a walbro 450 stock lines with 60lb injectors. On about 15lb with meth and my injectors are maxed out at 1/4 throttle. I would go bigger.
Stainless Works
13
Nov 5, 2015 03:31 PM
WICK3DxGATA
Aug 31, 2015 07:21 AM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
