Injector Flow vs Pump Flow
#21
Thats relatively easy, however, most people never put a pressure sensor on their meth system, and its impossible to determine flow without knowing the pressure.
#23
If I had run a 50psi base, my injectors would only flow about 560l/hr but my pumps would flow 525l/hr. That is nearly double my total fuel system capacity at 70psi base! If I had done this analysis before last weekend I would have gotten my 9 second pass almost certainly.
#26
Furthermore, its my personal opinion too much weight is put into injector data when you have properly sized injectors. Let me explain. Most of the non-linearity of injector behavior happens at very low pulse widths, so characterization is most important here. Unless you have an engine with extraordinary high specific output (ie, a 1.4L honda engine making 800hp), your injectors will most likely never go into that non-linear region. This is determined by the fueling requirements of idle vs max power rpm. This is especially true with a vacuum-referenced regulator. As long as the main flow rate vs pressure table is correct and the other tables are somewhat close, it will be fine. If your battery is good, voltage will not drop much during cranking, so that voltage offset table should only use a limited range. The min pulse width table should almost never be needed (unless very high specific power).
#28
There are 2 big things in his post...one obviously he assumes a much lower BSFC. I came to my assumption based on my fuel flow while on the dyno, ie, calibrated to my specific truck. Maybe we have all been assuming too low of one all along...
Secondly, which is related to the first, he is assuming crank horsepower, not wheel. You could account for this by assuming a higher BSFC, which is more similar to my example.
My chart seems to think a single walbro will tap out around 500-550 rwhp, which is about where every agrees they are maxed. Im curious what you had yours to, but also keep in mind the meth counts as fuel too.
#30
so an a1000 with 40 psi and a 160 lb injector at that psi will support?
so according to your sheet i need 1136 lb/hr pump and the a1000 does 800 at that psi at 13.5 v
Time for an upgrade
the 11104 pump should get me there at 1200 at same rating...
Time for an upgrade
I didn't look at the thread again today, but had it in my mind that you were predicting much lower for the 255 (like in the 400s).
