The Inevitable Stupid Pump/Sender Question...
Old Nov 1, 2015 | 12:42 PM
Velocity1's Avatar
Thumbs up The Inevitable Stupid Pump/Sender Question...
I've finally unleashed the Beast in my '00 ECSB 5.3L 4x4 and have to ask this stupid question whether for motivation, vindication, support?? LMAO..
At 158k on the clock....should I just go ahead and R2 the old one?
I'm feeding approx. 400+ flywheel, Custom Comp cam, 3.5" ORY 1 3/4" SS Long tubes, Custom SS FlowMaster design exhaust, extensive head work and radical ported intake and TB. Stage 4 65E and Circle D at 3600, Black Bear tune.
The reason why I shared the specifics is because if the consensus says change it out, the 2nd part of that answer is do I upgrade the pump?? Don't want to leave performance on the table, but not necessarily looking for any more either.
This is what we do when we're a Raven fan this season!!
Old Jan 1, 2016 | 12:46 PM
Velocity1's Avatar
Exclamation
I hooked up my hi dollar digital/analog fuel pressure gauge to the OEM fuel shrader port and I'm reading 42-44 psi at idle with the stock pump. I get the persistent P0300 CEL and flashing CEL. It's a 2000 5.3l return style system with stock oem injectors.
My question is what should the idle psi be? As soon as I drive it and mat the loud pedal, the light starts flashing, then sets and there's a profound miss. The only DTC it produces is P0300. Confirmed no vacum leaks and all sensors are new AC Delco.
Thoughts on what the problem could be? Black Bear says Lean/rich, rich/lean threshold values need to be adjusted in the tune.
Help!!
Thanks and Happy New Year!
V1
My question
Old Jan 4, 2016 | 10:11 AM
Last Call's Avatar
TOTM: January 2007
Help!!
V1
My question
I think the pressure should be between 55-62 psi. I would start by changing the filter, and then rechecking the fuel pressure.
Old Jan 4, 2016 | 01:29 PM
Atomic's Avatar
I have a gauge for that
That reading is correct. What does it say when you prime the key with the engine off?
0300 is random misfire...in 95% of cases I have seen its ignition related...burnt wires, cracked plugs, something like that.
Old Jan 4, 2016 | 05:47 PM
Velocity1's Avatar
The only numbers I've seen with both the system primed, engine not running and running is 42-44 psi. Fuel filter is a new Delco.
Ignition is all new. Taylor wires, MSD coils, NGK Platinums gapped @ .040. I'm one truck bed mount bolt/nut assy. away from allowing the installation of an AC Delco replacement. When it warms back up mid to later this week I'll cut the bolt off and raise the bed. Too cold to lay on the concrete and just perfect for sipping shine by the fire.....
I'm hoping it's the low pressure.
Old Jan 4, 2016 | 08:39 PM
Atomic's Avatar
Try the stock coils on there and double check no wires are touching the headers...
Old Jan 4, 2016 | 09:29 PM
1FastBrick's Avatar
Custm2500's Rude Friend
OEM state's Key On Engine OFF 55-62 PSI
From what I remember on my 2000, OEM fuel PSI spec on a Return Style is 48-52 PSI While running at Idle. Remove the Vacuum regulator hose from the regulator and it should raise up by approx 8-10 PSI to 58-62PSI
Mine was a solid 50PSI at idle and would jump to 58 PSI when the vacuum hose was pulled from the regulator at Idle.
The_W
Apr 28, 2026 09:40 AM
thundurchasur
Oct 6, 2015 10:01 AM
thundurchasur
16
Oct 4, 2015 10:33 PM
SquareOne
Oct 2, 2015 10:23 PM
FlowmasterMufflers
Oct 2, 2015 03:27 PM
