How to mount regulator on fuel rail (Holley Hi-ram)
Old Aug 8, 2015 | 09:38 AM
TAPyvehc93's Avatar
Default How to mount regulator on fuel rail (Holley Hi-ram)
For those of you running the Holley Hi-ram, how do you have your regulator mounted and routed? I just got mine installed, and I do not like how the shop mounted and routed the regulator. Plus I need to fix the kinked return line that they installed I was wanting to mount the regulator on the passenger side fuel rail and then run the return line under the intake, but I couldn't find an adapter fitting on Earls website that would seem to work. So...what did you all do? This is a NNBS converted to a return style fuel system to BTW
Old Aug 8, 2015 | 10:06 AM
George C....'s Avatar
Formerly ScreamingL
my old regulator setup, i used a union fitting
Old Aug 8, 2015 | 10:35 AM
GMCtrk's Avatar
Pics of the work and which shop was it?
Old Aug 8, 2015 | 01:47 PM
TAPyvehc93's Avatar
PM me if your really interested. I don't want to bad mouth any shops around here. I mean its not bad work but I just feel like they didn't take the time to think how to properly route everything.
Old Aug 8, 2015 | 01:49 PM
TAPyvehc93's Avatar
WOW! Looks clean.
Old Aug 8, 2015 | 01:55 PM
TAPyvehc93's Avatar
What brand fitting?
Old Aug 8, 2015 | 02:40 PM
Formerly ScreamingL
Magnafuel I do believe as it's purple
Old Aug 8, 2015 | 06:16 PM
blown02408's Avatar
02 w/ lowest mileage 2800
Mine is mounted similar to George's except on the front of the rail using an earl's -8 male orb to -8 male orb swivel, and there is also an aluminum bracket that runs from the regulator to the fuel rail mounting boss's to keep the regulator supported and keep it from spinning. Some pictures can be seen in my garage/album on here.
Old Aug 8, 2015 | 06:35 PM
GMCtrk's Avatar
If you need help installing anything I can help you out
The_W
Aug 15, 2015 08:07 AM
lxcoupe
Jul 21, 2015 02:12 AM
GMCtrk
Jul 17, 2015 06:39 PM
Deceptarado
Jul 8, 2015 05:24 PM
