Fuel System Questions For NNBS
Old Dec 12, 2012 | 05:10 PM
holley2346's Avatar
Default Fuel System Questions For NNBS
I have a 2008 tahoe which I believe has a returnless style fuel system. I am running 12 pounds of boost with 75lb injectors from FIC. I am spraying meth, but not using it as a fuel supplement. My pressure is holding just fine even at 12 pounds with a completely stock fuel system minus injectors. Keep in mind this was not a flex fuel truck. I saw a thread in this section where a company was releasing drop in kits for the NNBS, but can't seem to get any information about when they will be available.
I'm wanting to turn the boost up, so I obviously will need some more fuel for it. What are my options? I really don't like the price of a full blown custom setup, but even if I did how would I wire it in with the variable frequency stuff?
Just need some ideas guys, someone with a NNBS that has been down this road and upgraded would be helpful.
Thanks
Old Dec 12, 2012 | 05:32 PM
dick_landy's Avatar
The squash pumps are a drop in pump but the fpcm cannot control it so it will need to be turned off in the tune and you will need to run a return line.
Old Dec 14, 2012 | 10:39 AM
carbongmc's Avatar
I'll be testing my new fuel system in the next few weeks and I plan on posting how it works out. It is the factory pump and FPCM running like stock with a Walbro inline 255 ran off a 4psi pressure switch plumbed into the factory pumps feed. Not sure if it will do what I want as of now, but I dont see a reason it shouldnt.
RS/SS 4.8
Aug 2, 2015 11:03 PM
USMCvet0311
Aug 1, 2015 07:45 AM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
