Fuel system help..
So I'm almost done with kb turbo build I have 60lb injectors and stock fuel pump as of now, I've been looking into the boost a pump that kenne bell supplies, is that the way I should be heading or is there an easier safer way to go? Any input would help thanks guys.
Ok, so i've read some bad things on the KB BAP, is there a write up somewhere i didnt find about a good drop in pump, and what all is need to make it work on a 2008 l76 6.0L non flex fuel?
