Fuel pumps
Old Apr 12, 2015 | 07:46 PM
53RUSSELL's Avatar
Default Fuel pumps
Guys what external fuel pumps are you using? I looking for pump that can support 800hp and pretty quite under load. Any help would good thanks.
Old Apr 12, 2015 | 08:13 PM
Atomic's Avatar
I have a gauge for that
What kind of setup? It can be done easily with internal pumps.
Old Apr 12, 2015 | 11:08 PM
53RUSSELL's Avatar
Atomic,
This custom 67 Chevy Truck. The tank was designed to run external fuel pump.
Old Apr 13, 2015 | 12:12 AM
oakley6575's Avatar
Subscribed. I've been looking at the holley dominator inline pumps.
Old Apr 13, 2015 | 11:18 PM
53RUSSELL's Avatar
I was thinking running Aeromarine A1000. Has most people on here had good luck with them?
Old Apr 14, 2015 | 01:23 PM
03SuperSLADE's Avatar
Its a great pump for racing but not so much for a daily driver in my experience. I had one with the voltage controller and sump'd tank. After getting stuck on the side of the road 5 or so times with Vapor Lock it had to go. I couldn't drive more than half hour with anything less than a half of tank and if I went down to a quarter tank I would get cavitation on a quick stop.
My 2 cents...
Old Apr 14, 2015 | 08:38 PM
MikeGyver's Avatar
I will match your 2¢ and raise you 2¢, with this: You won't care how loud an external pump is under load, it is at the drive-up window where you want it to be quite quiet.
Old Apr 17, 2015 | 09:35 AM
sTNT971's Avatar
I'm using dual 044 fuel pumps its ready for 1000hp with 160lbs injectors
Old Apr 17, 2015 | 04:52 PM
black4.8's Avatar
i use a1000, but is loud and not good for over hour drive. most single pumps are all going to have the same issues. dual 044's would be a better setup for street.
Old Apr 17, 2015 | 10:09 PM
Atomic's Avatar
044s arent a good choice unless you run 30psi+ of boost. The walbro 400s and 450s are much better below about that boost level. Much smaller and quieter as well.
ss4chad
Aug 15, 2015 02:25 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
