Fuel pump upgrade
Stock fuel pump is starting to go out on me. Going to be building this truck to make roughly 500-600 hp with a TPP turbo kit. What fuel pump/injector set-ups are you guys running? Thanks for the input!
This ^^^ or even better a walbro 450 , that's what I run along with a racetronix hot wire kit and 60lb injectors .
Works for me but I also run meth .
Don't run a pump that's not a walbro , a walbro is proven and reliable.
Racetronix - FPA-021 - CK/SUV Fuel Pump Assembly
and Deastch 60# injectors. What are the benefits for the racetronix hotwire kit? Im also looking to run meth with my set up. What kind of numbers are you seeing with your set up?
Atomic- or anyone that can help. I am new to the truck game, this will be my first build. I see most of you saying to run these 400lph or 340's? Do you have to modify the stock hat and if yes or no is there a link for these pumps? or is it just a typical 340 or 400lph pump you are buying off lethal performance or another performance company and where do you get the pigtail adapter or how are you wiring them up?
Thanks
Thanks
Thanks
Thanks
