Fuel pressure drop at high RPM
Old May 11, 2018 | 04:42 PM
Kws82590's Avatar
Default Fuel pressure drop at high RPM
look for some input to point me in the right direction before i just start pulling stuff apart i have a 2012 GMC Sierra 1500 5.3 with a s475 Turbo the truck got dropped off to be dyno tuned yesterday and i got a call from them saying that at 6000 rpm the truck goes from 58psi of fuel pressure down to 38psi I’m running a walbro 450 with 88lb injectors we made 554rwhp on 15.4 of boost wondering if the factory wiring harnesses could be to blame or also wondering if my fuel pressure regulator location is to blame i know you want it as close to the rail as possible it is currently mounted on the frame rail under the driver door it has about a 2’ line from the regulator to the rail any input would be great thanks
Old May 11, 2018 | 11:33 PM
About20ninj45's Avatar
Is your writing coming off the battery or the alternator?
Old May 12, 2018 | 05:23 AM
Kws82590's Avatar
The battery
Old May 12, 2018 | 08:20 AM
03sierraslt's Avatar
I would never trust the factory harness to power a pump that pulls close to 20 amp at 60psi.
Is your regulator boost referenced?
Old May 12, 2018 | 11:29 AM
Kws82590's Avatar
Yes it is
Old May 12, 2018 | 12:36 PM
smokeshow's Avatar
Mod with training wheels
Still controlled by FPCM?
Old Jun 18, 2018 | 11:18 PM
707sendit's Avatar
Any progress on the fix? I’m having the same issue.
Ferocity02
Jul 17, 2015 07:05 PM
jddmj
Jan 15, 2015 09:25 AM
gmcyukon
Apr 11, 2013 05:41 PM
chiliz666
13
Jun 11, 2009 03:33 AM
