Flex fuel injector plug?
By any chance does any one know what style of plug the Flex fuel trucks use for the injectors???
mine uses EV6
Not sure what you're trying to do, but five o motorsports sells adapters ev6 to multec II, i used them on my last truck to run flex injectors..
My 06 truck is a flex fuel equipped truck and I need larger injectors for a new project.
I can order the larger injectors with what ever plug end I need. I have to specify which plug as they don't know which one it has or have that info. I also need to change the injector plugs on the stand alone harness for the engine Dyno. I would rather not have to buy a bunch off adapters since the plug style can be had on the injector at no cost. Thanks for your guys help. |
1 Attachment(s)
If your injectors and plug look like this, you have the ev6/ev14 style. If you have a small plug that doesn't look like this you have the multec II Delphi mini style injectors. Hope this helps!
