fast injector part numbers
Old Apr 16, 2013 | 11:47 PM
greasemykey's Avatar
Default fast injector part numbers
so i bought a set of fast 57 lb/hr injectors from a guy on here and in the tuning process we are having to pull so much fuel out to get it to run that he thinks i may have been screwed over. so with that said i pulled an injector and got this number 80507 off the side. can anyone confirm this number belongs to a 57 lb/hr injector so we can tune the correct numbers in.
thanks
Old Apr 17, 2013 | 12:41 AM
AKlowriderZ71's Avatar
11 Second Hall Moniter
Do the injectors say "FAST" on them? Could it be "30507"?? (1) LS3, L99, L76, LS7 Type 50lb/hr Injector Fuelairspark.com
One problem with tuning the FAST injectors is that very little tuning data exists for them... Sorry you're having troubles.
Old Apr 17, 2013 | 06:10 PM
mine are taller truck injectors. but it could say 30507. i guess im going to have to get in there and look again.
Old Apr 17, 2013 | 06:22 PM
i have run every number on here and google doesnt get me anywhere. but here are the numbers on the injector. raised numbers on the fast logo are 280 158 040
08 7 08 081112 on the injector tip its 80501 and above that on the plastic is PA6 and 927.
no numbers anywhere else on here.
Old Apr 17, 2013 | 06:45 PM
i called FAST and what do you know... they have no clue what they are either. so from what i have gathered my lsxrt intake is garbage because its warped on the intake seals and they build products without part numbers to identify them.
Old Apr 17, 2013 | 06:54 PM
cammed00's Avatar
Damn man that sucks. Guess you'll be looking for a TBSS intake soon? Can't you send it back to them and have them fix it or something?
Old Apr 17, 2013 | 07:16 PM
no i had to pay for a new lower intake. 250 later and it seals with no vacuum leaks. had to coat the upper plastic seal with a large amount of rtv. but the thing that is bothering me is that these injectors are acting like 33lb/hr because of all the fuel we are having to pull out of the tables to get this truck to run.
Old Apr 17, 2013 | 08:04 PM
skeet's Avatar
i have a set of the 30507 and they are the shorties. this number doesnt show on the injectors, its different, luckly i kept the info and package when i got them. wow that number you mentioned doesnt even exsist ( terrible ) glad i never invested in that intake, i knew it was useless and trouble before it came out.
sorry not much help, but you could send it to FIC and let them flow test the injectors, this will at lease let you know what you have ?
Old Apr 21, 2013 | 04:51 PM
finally got ahold of someone from FAST who has an idea of whats going on. these injectors are factory Delphi injectors that were modded by FAST. they are in fact 57 lb/hr injectors. now to find the proper injector data for Nick at Newtech Performance so he can get this pig running so i can giver her a break in. ill get video up on my build thread once hes done on friday.
Old May 3, 2013 | 07:01 PM
xx_ED_xx's Avatar
yeah fast rebuilds other peoples injectors mine are bosch rebuilds that are 85 pound, i had the same issue you did
