fast fuel rail plumbing
Old Jul 22, 2012 | 11:50 PM
greasemykey's Avatar
Default fast fuel rail plumbing
so while building my 383 i bought a fast lsxrt intake and fast rails. now i thought i bought all of the required fittings but found out that my alternator is way to close for my front mount crossover to fit. can someone take a pic and let me know what fittings they used to build their fuel system please. thanks.
Old Jul 22, 2012 | 11:58 PM
Atomic's Avatar
I have a gauge for that
That is always a trouble spot with big fuel rails...
Im using nasty performance billet rails on a stock L92 intake, fragola brand -8 an oring to -8an, and a 90 degree summit -8an hose end. I had to trim the back of the alternator plastic.
Old Jul 23, 2012 | 12:00 AM
did you just connect it to the front of the passenger rail?
Old Jul 23, 2012 | 12:05 AM
Atomic's Avatar
Correct
Pushing 1k+ hp and this setup works fine.
Old Jul 23, 2012 | 12:08 AM
sweet. so ill call summit in the morning and order 2 of the 90's and i should be good to fire this old girl up for the first time in almost 6 months
Old Jul 23, 2012 | 12:21 AM
black04's Avatar
I used redhorse performance fittings with my fast rails. They are -8 as well. Tightest 90* fitting i could find was the redhorse. Clears just barely without any trimming. iirc the -8 oring fittings in the rails are aeromotive.
Old Jul 23, 2012 | 11:56 AM
krambo's Avatar
I used the Aeromotive EOR to -8AN fittings for the rails and then a simple -8AN Jeggs 90* hose fitting. Fit just fine. Even more clearance if I went to a -6AN. I am using the larger case GM alternator as well.
jdb11386
Dec 3, 2015 09:34 PM
The_W
Aug 15, 2015 08:07 AM
TAPyvehc93
Aug 8, 2015 06:35 PM
Deceptarado
Jul 8, 2015 05:24 PM
