E85 conversion?
Been tossing around the idea to just go e85 instead of meth for my 6.0l turbo set-up. Getting closer and need to start gathering parts, so the question is what all do I need to get this going? I am hoping to be in the 600hp range what injectors should I look into? Fuel lines need to be upgraded? Fuel pump? Re-tune? What else....? Thanks
Do not know much about this so a point in the right direction would be appreciated, or a good write-up if one exists.
Truck info:
1988 GMC Sierra Reg Cab Truck
6.0 lq4
4l80e
Transgo HD2
3000-3600 stall thereabouts eventually
Future Turbo Build... 76mm 8-14 #'s
Isky Tripple 12 cam
ARP Head Studs
Katech Connecting Rod Bolts
LS7 Lifters
Comp 7.35 Hardened PR
Patriot Dual Valve Springs
Comps Cams Trunion Rocker Upgrade
Melling 10296 Oil Pump
TCI Flexplate
N-Motion Timing Chain set
LS9 Head Gaskets
TBSS Intake Manifold/Fuel Rails
Re-Gapped Piston Rings
3.43 gears
Aeromotive 340!
Meth Kit
60# Injectors
Racetronix Fuel Pump Harness
Nelson Performance re-worked harness
Truck info:
6.0 lq4
4l80e
Transgo HD2
Isky Tripple 12 cam
ARP Head Studs
LS7 Lifters
TCI Flexplate
LS9 Head Gaskets
3.43 gears
Aeromotive 340!
Meth Kit
60# Injectors
Thanks Alpine! Also what HP level would 80lbers cap off at? Just so I have an estimate.
i just maxed my 80#ers out on e85 i would est. they can take you to around 650ish whp at 100% + duty cycle . they took me to 15 psi ish on my camed 6.0 b4 i saw 100% dc. im running dual walbros right now dont know how much farther they will take me. if you are going to do a single pump i would recommend at least a walbro 400 at minimum . i upgraded to the new bosch 126# injectors from fuel injection connection , good stuff.
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
