e85 on 2014+ Silverados
Old Sep 26, 2018 | 08:00 AM
Jonblarc7's Avatar
Thanks FFDP
I haven't seen the dsxtuning kit, I knew about the CJtunes E85 kit. Seems like they are all 300 bucks. But for the gains I guess that really isn't to bad.
Old Nov 6, 2018 | 06:29 PM
JRoyPDX's Avatar
10 Second Truck Club
CJTunes - 14+ GM Trucks/SUV flex fuel conversion
Old Nov 8, 2018 | 12:35 PM
ozws6's Avatar
9 Second Club
Another option is to go with all factory fuel lines from a flex fuel truck. The parts below cost me $155. It takes a couple hrs to install since you are basically replacing all the fuel lines from the tank to the fuel rail. The hard fuel line that connects to the fuel rail (2317153) takes the most time.
Here are the pns from my 2016 6.2 8 spd. The 6 and 8 spd trans use a different hard fuel line (23171537 fit my 2016 8 spd) that goes from the flex fuel sensor to the fuel rail.
Sensor 13577429
Sensor Clip 20967866
fuel line 23171537
fuel line 23171538
fuel line 20967834
fuel line 23158923
I'd suggest checking with a dealer to verify pns for your year truck.
Old Nov 10, 2018 | 11:36 AM
JRoyPDX's Avatar
Sensor 13577429
fuel line 23171537
fuel line 23171538
fuel line 20967834
fuel line 23158923
I'd imagine these are different for each cab style and bed length though, yes?
Old Nov 11, 2018 | 08:12 PM
ozws6's Avatar
9 Second Club
I would suspect a couple of the pns for the hard lines could be different based on the truck configuration. The pns I listed were for a 2016 crew cab, short bed, 6.2 w/ 8 spd trans and 4x4.
Old Nov 13, 2018 | 02:54 PM
Better and cheaper to buy the GM parts. And it is a easy install.
Old Jan 29, 2019 | 02:11 PM
Jonblarc7's Avatar
Do i need any special tools to disconnect the factory fuel lines. I've never done anything like this before with fuel lines. So I"m not sure what I'm getting into.
It will be for a 2014 6.2 with the 6l80. So I guess I need to figure out what fuel line goes around that trans.
Old Jan 29, 2019 | 02:24 PM
Jonblarc7's Avatar
and is there any reason I can't do it this way on my 6.2 instead of replacing all the fuel lines
Old Jan 29, 2019 | 08:10 PM
Jonblarc7's Avatar
So after watching his videos a couple times I think I got a pretty good idea of what to do. For around 50 bucks it’s worth a try and I don’t have to cut anything so it can go back to stock if it doesn’t work. Since I have HP tuner he went over what to change there. Look like he’ll save me 400 bucks
Old Jan 30, 2019 | 08:42 PM
Jonblarc7's Avatar
I crawled under my truck this afternoon and I can splice the sensor in right were this guy did. But the plug connector is a lot farther away from that splice then it is on a regular cab.
Do you see any problem just cutting the plug wires and soldering the three wires to make the plug 2’ longer.
SteveDoten@ARH
Mar 11, 2014 01:14 PM
Ryan@Lingenfelter
Oct 8, 2013 06:52 PM
Hemi Killer
Jan 30, 2004 12:10 AM
K I L O
Sep 4, 2003 02:04 PM
sleek silverado
Apr 28, 2003 10:16 PM
