DIY Hotwire setup?
Other than that its not a difficult thing to build, just need the right connectors, right terminals, right grade wire, wiring loom, and relay. Use the original fuel pump wire to control the relay and provide a 10 gauge circuit to the alternator charge terminal and an equal ground to the frame.
I have a gauge for that
^ pretty much it. I have 2 pumps on mine, so 2 relays, 2 runs of 10ga wire from the relays to the pumps, and use the factory wire to activate one relay and either a hobbs switch or controller to turn on the second. The ground wires for the pumps are 10ga and go to the frame just outside the tank. The power wire for the relay is also 10ga and is straight from the battery.
BROKE-aSS-BLAZER
10-13-2017 03:50 PM
GMCtrk
18
10-06-2015 03:48 PM
