need help to figure out if fuel pump is dead
First i have a 2009 gmc Sierra Denali with a stock fuel system in place
Here my problem i had rear injector on passangers side leaking from o ring failed and it pouring gas out like crazy i drove it like this for about four blocks then the truck bucked and died will not start up the engine cranks over with no problem and the fuel guage doesn't move at all when the truck died it had a little more than a quarter of atank of gas in it i can't find the fuel relay or fuel pump fuse i looked in the fuse box for the fuse and relay but the spots listed doesn't have a fuse or a relay in the spots where the diagram said it should be can anyone help me diagnose the problem and maybe explain how to fix it properly thanks in advanced
No sound when key is in the ignition no movement of the fuel guage either so I'm hoping that a fuse or a relay burnt out from what i can from online the fuse and relay is under the bed but i haven't been able to crawl under and look yet
I will try it but before it died it red a quarter of a tank i had just put gas in it when i was done fill it with the amout i bought it red 3/4 full i dumped about a half tank on the ground
