Bypass Internal Regulator
Old Oct 23, 2017 | 12:06 AM
slowmo934's Avatar
Default Bypass Internal Regulator
In a returnless bucket is it possible to bypass the regulator? I have a Magnafuel 750 return setup also on the truck but when out of boost I would like the fuel pressure of the stock pump to be regulated by my under hood mounted regulator. The issue I have now is the stock pump shows 40psi on pressure gauge and my Magnafuel 750 when turned on has a base of 58psi. Would like to have both at 58psi but seems internal fuel regulator inside bucket keeps it a little low.
