Any one running 3 walbro's?
Old Feb 9, 2015 | 04:52 PM
GMCtrk's Avatar
Use E50 instead of E85.
Old Feb 9, 2015 | 05:03 PM
03sierraslt's Avatar
Why? After everything he has changed I doubt upgrading the fuel system some more is a concern enough to warrant the PITA of mixing fuel all the time.
Old Feb 9, 2015 | 05:06 PM
GMCtrk's Avatar
More headroom with no other changes and equal knock suppression to e85. And it's not a pita to mix, 1 part e85 to 1 part gas, easy.
Old Feb 9, 2015 | 05:22 PM
George C....'s Avatar
Formerly ScreamingL
A lot of Ford's use 3pumps
Look into a company named Fore as they make custom fuel hats for vehicles
We 1053rwhp on e85 thru a th400
-8 feed -8 return
Bosch 160s
Magnafuel 625 pump
44 base
IM not a fan of high base pressure you're better off at a lower base
One thing to inspect is pump voltage
Old Feb 9, 2015 | 05:35 PM
So that's how it works huh. Seems to me 50/50 would be E47.5?
You can't arque the simplicity of running one or the other.
Fyi- I can't type with sarcasm, I am just giving you a hard time don't read into it.
Old Feb 9, 2015 | 08:48 PM
Noah Burns's Avatar
just a thought... but why not stop stuffing walbros into a bucket and built a fitting fuel system for that bad *** truck?
Old Feb 10, 2015 | 09:06 AM
sprayedenali's Avatar
i might have a fuel cell for sale soon... just sayin
Old Feb 10, 2015 | 11:03 AM
thewrx's Avatar
And most e85 round here is about 70-75% anyways, so make adjustments there also.
Old Feb 10, 2015 | 01:03 PM
foose04's Avatar
Street truck, fuel cell is race truck stuff! Thanks for the help Atomic, I actually don't have a recent log as my computer broke at the track and I was on a borrowed setup.
I'm thinkin it would be easiest to go to Bosch 160s and run a base of around 40psi. That would cover up to 25psi and the walbros still flow pretty good at 65.
Old Feb 10, 2015 | 01:46 PM
Atomic's Avatar
I have a gauge for that
Yep, or you could run c16 and have 1400hp worth of fuel on the hardware you have.
