Any decent aftermarket truck rails yet?
#33
Try contacting Fore Innovations. They just designed a few LS specific rails. Mostly for the cars but maybe something will work.
#35
Have you yourself bolted LS3 rails to your nnbs? I'd be really surprised if the spacing for the mounting points are the same.
My solution was a set of professional products rails. Flipped the "L" brackets and drilled holes to mount them to on the 4 flat ridges on the intake.
First wide open dyno pull and I maxed the shorty injectors. Now everything has to come apart so I can add some spacers.
So for anybody reading this... as of now, this was the most cost effective way to accomplish the OP's question. Still nothing bolt-on to my knowledge. The market is just too small I bet. The oem rails will support the power that you're going to be using with the nnbs intake. If you have a return system, use a corvette filter. Anything more and most would be swapping to a Holley Hi-Ram or Fast.
It is also worth noting that all of this was in fact on a nnbs intake. There is a guy selling a bolt on set for the nbs on ebay. I did order a set from him and was going to just adapt the brackets, but he sent me a back order message stating that his CNC machine was backed up two weeks. I read this as he's expecting his conex box to show up from China in two weeks.
Suburban2500
Jul 19, 2015 04:50 PM
bk_cauley
Jul 8, 2015 05:37 PM
